Problems with Red Top
So we're thinking that both of these batteries are bad and I wanted to see if anyone else had this problem. I mean there's no way that a 4 month old battery..both of them should be bad. We're going to take them back where we got them on Friday. I just wonder if they had a bad batch???
Get the cheapest piece oh crap wet cell you can find and it will be better than an Optima.
I jump started the car, and it was fine and drove it to work and it charged fine afterwards. I bought a battery tender to plug into it while the car is in hibernation for the winter. The nice thing is it only applies a charge when it senses the battery at less than 12.5 volts, and then shuts off when it reaches 13 volts. So it never cooks the battery or lets it drop to low.
Pulled the one from my Z28 today to stick in my stepdads car. I've had that one over 3 years, no problems.
My POS wet cell dies after sitting in my car with no starting for 3 weeks at a time.
Check the following:
Parasitic draws on the system (BCM, stereo, nav, shorted light, etc)
Weak alternator, starter crapping out, etc (battery has to compensate - kills it)
Corroded cables INSIDE the cable insulation (VERY common with the POS Delco crap leaky battery)
Bad ground (due to above or all on its own)
Most people have the above problems and wrongly attribute it to the battery. Even the new, lower quality Optimas are twice as good as any junk wet cell "premium" battery.
Optimas are the only batteries out there that are designed to sit for weeks dormant and still (probably) work. I had one sitting in my garage six months, after being told it was bad by another shop. Started my buddy's Inifiti right up like a champ. Don't believe the hype, do all the checks and then check for yourself. I did have one Optima crap out early, AZone replaced it, no problems and no problems since.
