Sponsored by: CARiD
Idle Question
Old Nov 26, 2008 | 08:45 PM
JerseyLS1TA's Avatar
Default Idle Question
Ok just recently when I am driving down the road and I come to a stop the idle is usually at like 5-700 rpm's, every once in a while it will drop to 3-400 rpm's and will be rough and sound like it is going to stall but doesn't, not sure if it would if I sat there long enough it happens at a red light stop sign etc. But when i start driving again all is fine. No problems cruising or even at WOT. Anyone ever have this type of problem?
Old Nov 26, 2008 | 10:48 PM
Bad Lt1 Camaro's Avatar
yeah mine did that until i change the opit and plugs and wires. Mine had a miss in it real bad and once i changed that stuff it cleared it right up..also check fuel pressure. Should cure it up
Old Jan 29, 2009 | 09:31 PM
drel21's Avatar
00 SS with 26K and mine is acting the same way. Jersey let me know if that cleared it up. I have also heard it could be a vacume issue.
Old Jan 29, 2009 | 09:33 PM
nemss1's Avatar
*vacuum leak
*misfire
*bad battery/alt
Old Jan 29, 2009 | 09:47 PM
FormulaWs666's Avatar
I have the same issue damn it.
Old Jan 29, 2009 | 09:49 PM
LS6427's Avatar
Classic dirty fuel filter, MAF and/or injectors.
If no SES light, clean all that stuff. $25.00. One can a MAF cleaner and one can of Sea Foam and 1 new filter. Do the Sea Foam in the gas first, then change the filter.
If that doesn't help, you can then start looking elsewhere.
FiredUpZ28's Avatar
Any codes? Tune up and fuel filter I would recommend. Vacuum leaks will make a higher idle, usually not a low idle.
Old Jan 30, 2009 | 06:17 AM
lovin myls1's Avatar
Don't go and buy plugs and wires at 26k - can't see wasting money on that,they shouldn't be worn on that low a mileage car-try and diagnose it first to get to the real problem.
This site has info on how:
http://www.aa1car.com/random-misfire/
Let us know what you find.
Old Jan 30, 2009 | 09:39 AM
drel21's Avatar
No codes have poped up. This started happening about a week ago. Car has a Tune, Borla exhaust, lid, MAF, throttle body. Didn't sound like a vacume leak top me either. I will try to diagnose first. I will post my findings.
Old Feb 1, 2009 | 06:04 PM
Jeezer's Avatar
sounds like a vacuum leak or u just need a tuneup
Old Feb 4, 2009 | 09:18 PM
drel21's Avatar
Problem fixed! I cleaned the MAF, ran bottle of Sea Foam through engine for injectors and little through intake, and replaced the fuel filter. Seemed that I was not getting enough fuel at idle due to dirty injectors and dirty fuel filter. Thanks for the help guys!
Old Feb 4, 2009 | 10:08 PM
nemss1's Avatar
good deal man
Old Feb 4, 2009 | 10:20 PM
FiredUpZ28's Avatar
Glad you figured it out
