weird idle
i didn't know if this was something to worry about. Thanks for any help.
You could disconnect the battery for 30 minutes to reset the PCM. But I think you just need to drive it for a little while. Maybe do an idle re-learn procedure, that can't hurt.
Could a bad purge solenoid or vent solenoid really cause this problem? That is the only code coming up. The other two were o2 sensors, but i replaced those a week ago from this past sunday.
hey babylamb, how much was the IAC motor?.....as long as it's not like $500 i'm fine with the amount it cost.
Good luck, I wish I had more advice
