Sponsored by: CARiD
key problems
Old Dec 4, 2008 | 06:36 PM
95firebird5.7's Avatar
Default key problems
ok so my key wont come out when i turn the car off. i have to put it in accessories mode for the key to come out and then my stero stays on. how can i fix this?
Old Dec 4, 2008 | 06:49 PM
2002_Z28_Six_Speed's Avatar
I would say you are going to have to replace the lock cylinder.
The mech that keeps the key in is inside of the lock cylinder.
It is not possible for the lock cylinder to be clocked wrong with the actuator rod and sector gear.
MEBBE the ign switch is not positioned right.
Old Dec 4, 2008 | 07:09 PM
how would i go about fixing this? is it hard?
Old Dec 4, 2008 | 11:10 PM
Replacing the lock cylinder wouldn't be too hard. You would need a steering wheel puller and a locking plate removal tool. A torx bit holds the lock cylinder into the upper steering column housing.
Adjusting the ignition switch on the column wouldn't be that hard and require no special tools. Just drop the column and then adjust the position of the switch.
