Sponsored by: CARiD
My Hood is Stuck!
Old Dec 6, 2008 | 11:35 AM
LavaRock's Avatar
Default My Hood is Stuck!
After seeing the SES light flashing I stopped to check under the hood, but the hood wouldn't pop open? Pulling on the latch inside the car is weak (as best I can describe). What can I do?
Old Dec 6, 2008 | 11:43 AM
sdavis2702's Avatar
What car
Old Dec 6, 2008 | 12:06 PM
LavaRock's Avatar
99 Camaro Z28
Old Dec 6, 2008 | 12:28 PM
th41427's Avatar
Default My experience
My sonoma does the same thing. when you pull the release latch in the vehicle it seems like it never releases. but if i would go to the front of the vehicle and tap the hood close to where the latch is located firmly, it would release the hood like it was supposed to. good luck
Old Dec 6, 2008 | 12:54 PM
SparkyJJO's Avatar
when you get it open grease it good
Old Dec 6, 2008 | 01:17 PM
LavaRock's Avatar
I got it open! Pushed the hood down real good, then pulled the release latch with same results. But, then I went to the front of the hood and somehow got my fingers in there and pulled up. It released? Also, I found the cause of the SES light...a spare plug wire came off.
Old Dec 6, 2008 | 04:27 PM
SparkyJJO's Avatar
ya it is sticking. When you pulled the latch it released it but it wouldn't spring upward. If you try and just pull on it without putting the latch it won't come up.
