Sponsored by: CARiD
rattle?
Old Dec 7, 2008 | 02:12 PM
79Jeep's Avatar
Default rattle?
it started yesterday. went out to drive today and started it up and it ratteled pretty loud initially then stopped. i started driving and it doesnt make any noise under accel. but under decel it ratteles alot. it make a slight noise at idle. it sounds like it is hitting the passanger floor or at least coming from that area. im guessing its a heat sheild or the cat.
by the way its a 98 z28
anyone have a similar problem?
thanks matt
Old Dec 7, 2008 | 03:40 PM
bobbyd's Avatar
check the heat shields i had to remove my drivers side today for the same reason..
do you have LT's? if so could be yout ypipe banging
Old Dec 7, 2008 | 03:46 PM
79Jeep's Avatar
no no longtubes, stock i just have a magnaflow catback
Old Dec 7, 2008 | 04:29 PM
bobbyd's Avatar
ok then yea check the heat shields make sure they arent rubbing or make sure that its not touching the cats/pipe/o2 sensors.
if its not that then maybe the cats are clogged or something
Old Dec 7, 2008 | 06:24 PM
79Jeep's Avatar
a cat can make a rattle?? wow!
if that turns out to be be the case then it looks like lt's and a ory pipe!
but i will prolly check everything out tomorrow and let you know what find.
thanks matt
Old Dec 8, 2008 | 04:22 PM
79Jeep's Avatar
well it looks like it was just the exhaust hitting the crossmember peice. it wasnt hitting the tranny crossmember but rather the one behind it.
do i really need this peice for structure? its not like its supporting the exhaust or tranny?
Old Dec 8, 2008 | 04:41 PM
bobbyd's Avatar
nope you can remove it.
i removed mine the other day since mine was also hitting
good thing it was nothing big
Old Dec 8, 2008 | 05:55 PM
79Jeep's Avatar
alright sweet i will prolly remove that too.
good thing it wasnt a cat goin bad.... didnt really want to buy lt's any time soon lol
