Power steering
Mine stated leaking and all the replacement ones I have seen only come as the pump or the pump and resivoir....
thanks in advance
Remember to check the new pump's box for 2 new o-rings. One goes on the high-pressure hose (the one that screws into the pass side of the pump) and the other goes on the bottom of the reservoir (bottom-center where it plugs into the top of the pump).
It's also a good idea to replace the high-pressure hose itself for about $25. It helps if you have a set of flare nut wrenches. I think one side is 18mm or 15mm and the other is 18mm or 5/8" - confirm with standard wrenches before running out and buying anything.
