Sponsored by: CARiD
y-pipe question
Old Dec 14, 2008 | 07:30 PM
TgizziSS's Avatar
Exclamation y-pipe question
i have a jet hot y-pipe and recently hit a huge bump and dented the left side seggment is there and way i can just buy that segment and replace it instead of buying the whole assembly and if so where can i buy that at??
Old Dec 15, 2008 | 05:31 PM
98boxer's Avatar
If its not that restricked i wouldn't replace it. Remember how bent the stock y-pipe is. I would check with the sponsers here.
Old Dec 15, 2008 | 06:38 PM
TgizziSS's Avatar
its brent pretty bad but its not restricted im still able to drive it, i just didn't know how it would affect it.
Old Dec 15, 2008 | 08:12 PM
samson_420's Avatar
Post a pic of the dent.
Old Dec 15, 2008 | 08:47 PM
jimmyblue's Avatar
Moderator
If it's crushed to no worse than half its original thickness and
only in a spot, I would leave it be. A small dimple won't bother
anything. Since the Y comes apart in several pieces (at least,
my "catted" one with the cats replaced by steel tubes) you
might be able to peen it out some with a piece of 2" iron pipe
as an inside "anvil". But you're pretty much guaranteed to ruin
what's left of the coating that way....
