NEED HELP. Car Bogging
p0131 and p0171 which i think is lean bank 1 sensor 1. Ive replaced the o2 sensor like 3 times and the code still keeps coming back?
Ive taken it too my tuner and he said to check the fuel pump. But it shows normal. And ive always replaced the fuel filter no more than 10000 miles ago. The car has 120k on same plugs? Is it time for new plugs or something else. Anyone else have problems like this
The car only has just a tune, true duals, intake and gears.
-ANY help would be greatly appreciated!
It might be fine at idle, but dropping pressure at WOT because it can flow enough, which causes a lean condition.
If you can scan the car while driving, have a look at the injector duty-cycle, which should give you an indication of how the fuel-pump is behaving.
If your fuel-pump is going out, it wont be able to deliver enough fuel-pressure for the car to reach stoich, and it'll run lean (which the codes indicate).
Now, by checking the injector duty-cycle, you'll see how hard the injectors are trying to compensate for the lean condition by adding more fuel. If the injectors are working at 100%, and the fuel-pressure drops while at WOT, you're looking at replacing your fuel-pump.
However, if your fuel-pressure doesn't drop, but the injectors are still at 100% while at WOT, you might be looking at swapping O2 sensors.
You can check the injector duty-cycle with HP Tuners for instance.
