Sponsored by: CARiD
Trip odometer resetting?!!
Old Nov 24, 2008 | 02:18 PM
airmaxon1's Avatar
Default Trip odometer resetting?!!
So on occasion, when I turn my car on after sitting, the trip odometer resets and the gauges will all shoot up to the top, come back down then go to normal. But then sometimes if the cars only sitting for half hour maybe and I start again, everythings normal? what is going on here?
Old Nov 24, 2008 | 02:23 PM
2001NBMZ28's Avatar
Is it a '99? Was a common problem with low battery voltage. GM issued a TSB on it to replace the gauge cluster - but a good battery makes it go away.
Old Nov 24, 2008 | 02:38 PM
airmaxon1's Avatar
yeah it is a 99'. a TSB, really? How would I find out about that? but replacing the battery is a fix too, guess I gotta go with that then
Old Nov 24, 2008 | 03:21 PM
2001NBMZ28's Avatar
TSB# was 99-08-49-009 about trip odo resetting, doesn't mention the gauges sweep, but usually happened at the same time. If the battery is a few years old bring it somewhere for a free load test.
Old Nov 24, 2008 | 10:16 PM
airmaxon1's Avatar
alright, i plan on doing that tomorrow. if the battery does the trick, much easier than the gauges. thanks for the help.
Old Dec 15, 2008 | 01:03 AM
JamesR311's Avatar
does that mean I could go get a new cluster now or is it too late? Mine was doing that but I got a new battery that stopped the flickering lights and a slew of other problems previously blamed on the alternator.
Old Dec 15, 2008 | 08:00 PM
bigcraig987's Avatar
Work for TSBs is only free for vehicles still under warranty, so you could get a new one but you would have to pay for it
Old Dec 17, 2008 | 03:56 PM
SSucese's Avatar
My 99 had the same problem many years ago, every time the temp dropped below freezing it would reset. Fortuanatly i was still under warranty as they swapped my cluster out for me.
