Sponsored by: CARiD
Keep blowing headlights
Old Dec 22, 2008 | 04:23 AM
TireSm0ke's Avatar
Default Keep blowing headlights
Lost one last week, replaced it and then the other side went out... bad ground?
Old Dec 22, 2008 | 06:25 PM
TireSm0ke's Avatar
ttt... could it have to do with the illumination wire on the radio? I disconnected because it would cause problems with my headunit... but I may have left the lead exposed.
Old Dec 22, 2008 | 07:24 PM
9000th01ss's Avatar
It has nothing to do with the illumination wire on the radio. If that wire touched anything it would blow the fuse for the instrument panel lighting.
I had an alternator problem caused by rain once, the volt gauge showed 17+ volts.
Both headlights blew out.
What brought it to my attention was the ASR, brake, abs inop, airbag lights would come on when the voltage went over 17.
Old Dec 22, 2008 | 07:57 PM
W es 6's Avatar
I have had a similar problem with my car... both sides have gone out twice in the last 6 months.. if you figure out what's causing it make sure and post it on here because i'm not too good at figuring out electrical problems
Old Dec 23, 2008 | 12:40 AM
TireSm0ke's Avatar
Its driving me crazy and I really dont want to keep buying new headlights. Does anyone know what could be causing this?
Old Dec 23, 2008 | 07:41 AM
wssix99's Avatar
Save the manuals!
Its also happened to me. My bulbs always go out within a few weeks of each other. On the surface, this shouldn't cause concern, especially if the bulbs were installed at the same time. Bulbs have a finite life and are consumabele. If they were both installed togeher, they will always "burn" at the same times and it would make sense that they would run out together.
Now, last year - I replaced my original headlights (which lasted me 8 years) with some of the new, expensive Sylvania ExtraVision bulbs. Those turned out to be total duds and only lasted me one year. They too burned out at the same time. The quality definitely wasn't there on this set. I replaced them with new ExtraVision bulbs and if these go out in the same way - I'm going to flip.
Old Dec 23, 2008 | 07:44 AM
wssix99's Avatar
Save the manuals!
Originally Posted by W es 6
I have had a similar problem with my car... both sides have gone out twice in the last 6 months.. if you figure out what's causing it make sure and post it on here because I’m not too good at figuring out electrical problems
W es 6, What kind/brand of bulbs have you been installing? If you have Sylvanias, they have a satisfaction guarantee. (Check the instructions on the back of the box.) All you should need is you receipt to get replacement bulbs directly from the factory.
Old Dec 23, 2008 | 07:49 AM
Phoenix216's Avatar
i posted something like this a few weeks ago and no one seemed to have a clue then either. i thought it was only me that was having this kind of problem. i had to replace my headlights twice in 6 months, continually have to replace my front turn signals because they've each blown out at least 2 or 3 times, and my steering wheel radio control lamp on the left side...no alternator issues like 9000th01ss described, but my volt gauge does read pretty high when i first start up, probably around 16-17 as well.
Old Dec 23, 2008 | 08:40 AM
AxisOfOil's Avatar
i leave a gps unit plugged into my cig lighter all the time to keep my battery under 16 volts on startup. there are some downsides to a good alternator i suppose. high voltage does indeed fry bulbs though.
Old Dec 23, 2008 | 08:54 AM
crzytown69's Avatar
i was having this issue even the gauges would go hay wire and the car even stalled once... i came to the conclusion it had to be a ground so when i did my motor swap i used some amp wire and made two new grounds one for each side been fine ever sence
Old Dec 23, 2008 | 04:18 PM
W es 6's Avatar
wssix99 -- thanks for the tip i am using sylvanias next time i'll definitely check out that satisfaction guarantee
