Sponsored by: CARiD
Need help!
Old Dec 24, 2008 | 04:47 PM
LS2Z28monster's Avatar
Default Need help!
I have a 98' Z28 a4 with an LS2 swap. So the car is idling good at first but has 500-750rpm jumps sometimes. The car is also slow to crank. The car also dies everytime I put it in reverse or if I'm coming ti a stop. I'm assumingit has to be an idle problem. I've checked for vacuum leaks and can't find any, cleaned out the IAC and now I'm stumped. Somebody help me out.
Old Dec 24, 2008 | 04:52 PM
LS6427's Avatar
First, get it scanned wioth a real OBDII scanner at the dealership, not at Advance Auto or PepBoys with that little yellow scanner.
Then see what you have goling on. It can be a dozen things.
Old Dec 24, 2008 | 06:09 PM
Any ide how much that costs?
Old Dec 24, 2008 | 08:06 PM
LS6427's Avatar
The dealership....probably like $50.00 for a scan. Not sure though.
I PM'ed you but it kept taking forever, so I don't know if it went through.....so here's what I Pm'ed you.
If you want to, you can also call Norris Motorsports or Macedo Motorsports, one is in Winter Garden and the other just moved to Sanford. Both are very good shops and I have gotten free scans (the good OBDII scanners) by both of those guys when I lived there two years ago. Larry Macedo and Mike Norris, both very good guys. I would bet they would do it for free for you. I gave you the links so you can figure out where they are in the Orlando area.
Call these guys, I bet they both say to bring it right over.
Larry Macedo: 407-246-6511
http://www.macedomotorsports.com/
240 Power Ct. Suite 140
Sanford, FL 32771
Mike Norris: 407-616-2518
http://www.mikenorrismotorsports.com
101 First Street
Winter Garden, FL 34787
Good luck
