Coolant in p/s pump
Get underneath it, follow the PS Lines. The metal one coming from the Pump should be going straight to the Rack(Pressure side). The other one(Low side) will be going from the Rack to the Cooler, then from the Cooler to the Pump. Take that one, you may have to get a Brass Barb to connect them both, and make the Low side run from the Rack to the Pump. Then plug the holes on the Cooler.
I'm about to just replace that whole section with just a hose, it's useless junk there at the moment.
