fuel filter
It's the fuel PUMP that is in the tank.
To the original poster: the fuel filter is on the inside of the under body near the rear drivers side wheel well. One end screws in and is removed with a couple of wrenches or even pliers. The other end is a quick connect fitting that you can take off with a special tool, but that isn't really needed. I just use a small screwdriver to push the tabs in. You might have a little trouble the first time you do it, but you DO need to learn how because it needs to get done at least once per year. I have a couple ramps that I use to drive the front up on to get under the car to change the oil. They also work great for changing the fuel filter if you back up on them to raise the rearend.
Buy a new fuel filer and crawl under the rear of the car and look for something that looks just like it. Oh.. you will probably get gas ALLL over yourself the first time, so park away from the house, have a towel handy, and no smoking.
I was being nice, I was giving him a good pointer about how to get into the Tank easier.
No ****..?
I'm pretty sure if you looked at my sig, I've probably gotten into the Fuel TANK to upgrade the Pump I have..
Cheers.
Cheers.
Don't forget to relieve pressure by depressing the schrader valve in the engine bay, as well as removing the gas cap. And get a pan or something to catch all the gas that will come out, no point in spilling it all on the ground.
We're all good. Just wanted to give the guy a break and not see him flamed.
