Sponsored by: CARiD
something wrong with my vents
Old Jan 1, 2009 | 08:35 PM
slvr98camaro's Avatar
Default something wrong with my vents
hey guys, heres whats goin on..
i had the heat on, and the vents blowing on the floor, i changed it to come out from the top for a second so i could warm my hand up, then put it back to the floor.. only it didnt really go back, there was still a ton of air blowing from the top vents.
when i move the **** around, i can hear the vacuum noise, and i could hear the deflectors (or whatever you call them) moving a bit, and when i set it to floor, there was some air going down there, but the majority was staying up top
whats goin on here?
Old Jan 2, 2009 | 06:29 PM
Martin HD-28's Avatar
Have you checked the rear of your intake? There's a vacuum line back there, if it's not on tight, it may cause issues similar to what you're talking about. If you've swapped your intake recently or even been in the engine bay, you may want to check it.
Old Jan 2, 2009 | 07:10 PM
thanks, i havent, but i will take a look
i wasnt thinking it was a vacuum problem since if i start my car, then shut it off, i can hear the vacuum noise coming from the dash a few times before it "wears off"
Old Jan 3, 2009 | 01:43 AM
weird story, but it seems to have fixed itself, used the car today, and the vents were working on the floor again.. although i didnt change anything, just quickly went to floor
i think i have some magical car, every single problem i have had with it has fixed itself.. ticking lifter, vents, slipping clutch
