changed brake pads now ABS light on
when ou changed your brakes, you probably accidentally knocked a wheel speed sensor off, which will light your ABS light up
im sure you checked, and you dont have low coolant? im not sure where exactly the sensor is, but it is probably plugged into the rad
No I did not bleed them.
Coolant is fine, no leaks and has stayed at a good level. Coolant light has been on the car for about 6 months, it WAS low then, I added coolant and it's just never went off.
The ABS light is now off...No idea. I had to brake hard over the weekend due to some idiot and it suddenly went off. No idea
Do I have to have like Advanced Auto or some where scan for the code #'s then have someone remove them? I dont want the mechanic who's doing the inspection to **** me over saying he needs to fix such and such.
