'95 Formula Exhaust Question
I could just cut the old pipe out, since it is not being reused. But, I wanted to learn the tricks before jamming my new I-pipe up in there and trying to get it to fit.
Thanks for any help.
The i-pipe is free of the muffler, and the muffler is out. It's just that I can't remove the i-pipe from the car, because I don't have the height/angle to pull it out the front. Basically, what I discovered, is that I need to disconnect the panhard on the PS, and whatever the bar is above it, too, in order to get the room needed to pull the pipe over the axle and out. There isn't enough room between the top of the panhard/bar above it and the body of the car to angle the pipe out over the axle. If I had a lift, this probably would not be an issue. Just making a simple job take longer and delay my car being back on the road
So you kept the car? Did you do the T56 swap?
What kind of catback did you get? On most of the aftermarket units the I pipe is in two pieces, a straight piece and then an over the axle piece so you don't have to drop the rear. Or did you buy a stock catback? If that's the case you probably will have to drop the rear.
Nice to hear you still have the car. Let me know if I can help.
