Sponsored by: CARiD
Water pump, hard to do?
Old Jan 16, 2009 | 01:54 PM
sman's Avatar
I know exactly what your talking about, it drove me up the wall, I ended up rubber banding a shop rag around it to shut it up, haha.
Old Jan 16, 2009 | 03:56 PM
BTTM's Avatar
Ok I've changed the water pump. But the car is still overheating. I noticed the lower radiator hose is warm and the upper radiator hose is cool. Also, there is no heat when the heater is turned on. Just cold air.
What's the verdict...a crappy water pump from autozone or a crappy thermostat from autozone? Maybe just crappy autozone.
Old Jan 16, 2009 | 04:07 PM
bjamick's Avatar
^^ That would be a thermostat.
Old Jan 16, 2009 | 05:04 PM
BTTM's Avatar
That's what I was thinking also.
Sucks, I just replaced the thermostat about 6 months ago.
Old Jan 16, 2009 | 05:09 PM
LS6427's Avatar
New t-stats don't work alot of the time.
Old Jan 20, 2009 | 02:12 PM
Dave 96TA's Avatar
You can always test your new thermostat by dropping it in a pot of (hot) water before installing it. If it doesn't pop, take it back!
Old Jan 23, 2009 | 03:47 PM
kraemer94's Avatar
I'm about to change the one in my car as it's bad. Is any sealer needed?
Old Jan 23, 2009 | 04:23 PM
LS6427's Avatar
No sealer needed for the water pump or the t-stat. Water pump has gaskets, t-stat housing has an o-ring.
Old Jan 23, 2009 | 04:49 PM
kraemer94's Avatar
Thanks! I have the two metal gaskets, Don't look like much so that why I was asking. Does it mater which way the gasket faces?
Old Jan 23, 2009 | 05:03 PM
eseibel67's Avatar
Might be crappy parts, but you may just have an air buble that needs to be burped out.
Old Jan 23, 2009 | 05:13 PM
sway99bird's Avatar
It's not that bad it's on the front of the motor and you have sorta easy access so go for it !
Old Jan 23, 2009 | 05:14 PM
  #32
LS6427's Avatar
THose are crush type gaskets, as you tighten them the gasket crushes into position, thats why you don't need sealer. Well, they should just fit one way with the holes lined up, but I don't think it matters.
Old Jan 23, 2009 | 05:19 PM
  #33
kraemer94's Avatar
I notice that one side the rubber part is flat on one end and the other sticks out a little. These are ACDelco Gaskets if that matters at all. Thanks again for your help.
Old Jan 23, 2009 | 05:47 PM
  #34
LS6427's Avatar
Put the flat side against the block.
Old Jan 26, 2009 | 09:05 PM
  #35
BTTM's Avatar
I have replaced the thermostat which didn't solve the problem. Hoping it's just a bubble as I don't feel like replacing the water pump.
I guess I'll bleed the radiator. Any special trick to this on f-bodies?
