Sponsored by: CARiD
Help!!!!! P0102, P0135, P0155
Old Jan 5, 2009 | 12:21 PM
96RamAirTA's Avatar
Default Help!!!!! P0102, P0135, P0155
These codes went off yesturday need help car seems to run alright while cruising but idles rough and dies occasionally waiting at a light any help would be greatly appreciated.
Old Jan 5, 2009 | 12:36 PM
2001NBMZ28's Avatar
Remember your other posts - so the fuse is OK and you found the problem? After my Vig install my idle would "hunt" at low speeds while coming to a stop or going into reverse while parking. I got a tune to increase the in gear idle, line pressure, remove torque management, etc.
Old Jan 5, 2009 | 02:03 PM
96RamAirTA's Avatar
yea i remember the other post but know the fuse i quess keeps blowing ever after i just replace it....ive checked the o2s and the lines look ok to mee no breaks or anything....i think the maf might went out???
Old Jan 5, 2009 | 02:41 PM
2001NBMZ28's Avatar
You've got to find the reason the fuse keeps blowing, still think it's an 02 harness, or something else on that circuit, short caused by something the tranny shop did when they installed your TC. Have you contacted them about it? I'd ask them to put the car on the lift and look around. Just started after they worked on the car right? Visit gearchatter.com and look up the diagnostics for 102, 135 and 155 - might find something there, but all the diagnostic charts for those codes say check the fuse. Hang in there, sure you're frustrated.
Old Jan 5, 2009 | 04:58 PM
96RamAirTA's Avatar
yea just a little frusterated! that and the wife adding to it!! lol well thanks ou think if i replaced the 02 that would help or maybe the o2 extentions for the LTs??
Old Jan 5, 2009 | 05:14 PM
2001NBMZ28's Avatar
Get them to put it on a lift for you and check them before buying anything. All it takes is for an 02 harness to arc on a LT somewhere or pinch it between the housing and it'll fry the ENG SEN fuse.
Old Jan 11, 2009 | 01:34 PM
96RamAirTA's Avatar
well i looked al under the car for a broke wire on the o2 extensions but couldnt find one but the drive side o2 right before the plug was melted so i went head and swapped them out.... so hopefully that will take care of that i hope... but car through a new one... which i made a new thread about thanks man!!
Old Jan 11, 2009 | 02:24 PM
96RamAirTA's Avatar
ok went and swapped fuses and still blow right as i started car... but car does seem to run smoother than before.... use to idle rough but seems to cleared up that
Old Jan 11, 2009 | 05:34 PM
00silver6's Avatar
i dont know if you knew what the codes was or not just trying to help. hope you find it.
p0102- mass air flow circuit, low input
p0135- oxygen sensor heater circuit malfunction (pre converter sensor, left bank)
p0155- oxygen sensor heater circuit malfunction (pre converter sensor, right bank)
Old Jan 11, 2009 | 05:53 PM
96RamAirTA's Avatar
i knew what they where ive looked them up numerous times but cant seem to get rid of them
