Sponsored by: CARiD
Weather stripping maintenance?
Old Jan 5, 2009 | 02:45 PM
Adam2001WS6's Avatar
Default Weather stripping maintenance?
Is there any recommended maintanence to perform on the weather stripping on the t-tops and rear hatch? They aren't leaking and are nice and soft and I would like to keep them that way. Any recommendations for lube, grease, etc. that is good and won't eat the rubber would be much appreciated.
Thanks,
Adam
Old Jan 5, 2009 | 03:42 PM
2001NBMZ28's Avatar
Owners manual says wipe them down periodically with dielectric silicone grease and gives a GM PN, surely cheaper at your local parts store.
Old Jan 5, 2009 | 05:04 PM
Formula413's Avatar
Silicone grease works great, I use it on my daily driver too, keeps the doors from freezing shut in the cold. I actually found it in the plumbing section at a hardware store, comes in a little 1/2 oz tub. Make sure you get silicone grease, not silicone spray. The spray is way too thin to do any good.
Old Jan 5, 2009 | 10:28 PM
I will look for some the next time at the parts store.
Thanks.
