Sponsored by: CARiD
Reverse Light not working
Old Jan 16, 2009 | 10:52 AM
ls1jabroni's Avatar
Default Reverse Light not working
Okay. So for the past few months my reverse lights have not been working whenever I am backing up. The other day some dude almost ran into my car because he was impatient and wanted to pull out 1st. I need to fixed b/f that happens again.
The lights are fine and are not blown. I think it might be electrical, however I am not very familiar with the wiring.
Can someone point me in a good direction to start? Has anyone else had this issues b/f?
Old Jan 16, 2009 | 12:27 PM
f-bodyguy's Avatar
not being a dick but the bulbs might be bad after all happed to my dr side rear turn signal. they looked good but couldnt find anything else wrong so i changed them and that worked....maybe get a voltage tester and have some one put it in race and see if the wires are getting power
Old Jan 16, 2009 | 12:30 PM
the_merv's Avatar
Veteran: Air Force
Check the Fuse for that in the Fuse Box, then check the Wiring on the side of the T56.
Old Jan 16, 2009 | 01:26 PM
ls1jabroni's Avatar
No worries F-bodyguy, the voltage meter would have been a smart idea when I had the taillights off. I will try that approach and see what happens.
All of the fuses are good and the wiring if fine.
Old Jan 16, 2009 | 01:47 PM
m6speed's Avatar
mine did that before, i put in dual filament bulbs and they worked again
Old Jan 16, 2009 | 01:55 PM
nemss1's Avatar
try the neutral safety switch under the center console and check voltage to the reverse wire
