how can i search for my codes
how i can find them
i heard someone said switch off and push gas paddle 3 times,
put the key in and turn it to ignition switch
i did that n nuthin happened
But seriously, IIRC the OBDI cars could be scanned by a certain sequence, but not the OBDIIs. Your best bet is to find an auto parts store that will do it for you. Or buy a scanner, $50 or so.
but ummm
i know a trick on mustangs
switch off, hold the mileage stitch,switch to to accessory
then a lot of things will show up on the dash ( on the mileage )
u can read a digital speed,wether degree,oil temp,water temp....etc
is there anything like that with camaro
but ummm
Go to Advance Auto or Pep Boys...they will scan your car for you FOR FREE. They will tell you what codes are being activated by the PCM and then you can look them up in the book. But...those cheap scanners sometimes don't pick up certain codes on certain peoples cars. The OBDII scanner that the dealerships use is the best one to use.
