Sponsored by: CARiD
power steering??
Old Jan 19, 2009 | 07:04 PM
FL-LS1's Avatar
Default power steering??
How do I get the tank off the power steering pump?? I need to remove the high pressure line. Please help!!
Old Jan 19, 2009 | 07:32 PM
FL-LS1's Avatar
help!!!!!
30th t/a's Avatar
You dont need to remove the tank. To remove the high pressure line all I did was remove the pulley and use a wrench. I think you can get to the line without removing the pulley but it is a pain.
Old Jan 19, 2009 | 07:50 PM
FL-LS1's Avatar
how do you remove the pully?
Old Jan 20, 2009 | 12:00 AM
nrs2420's Avatar
you need to get a puller. You can rent them at an auto parts store, but I too would like to know how to take off the reservoir.
Old Jan 20, 2009 | 11:03 AM
30th t/a's Avatar
yea go to advance and rent the GM power steering pulley remover.
The tank is easy to get off. there are 2 clip like things that hold it to the pump. Once you have the assembly in your hand you will see what im talking about. I took a flat screw driver and tapped the end of the clips till they slid off releasing the tank from the pump. then you just tapped them back on when reinstalling the assmebly.
Old Jan 21, 2009 | 05:55 AM
FL-LS1's Avatar
This puller will fit with the fans on the car?
Old Jan 21, 2009 | 10:26 AM
nrs2420's Avatar
I don't know, I know you don't want to use a 3 jaw puller because it can bend the pulley. I've never taken of the pulley so I can't honestly saw, but i did see antoher thread around here that shows the pulley a guy rented from Oreilly's and he said it worked.
Old Jan 21, 2009 | 11:07 AM
30th t/a's Avatar
when I remove the PS pulley from my car, I take the fans and radiator out so I have as much room as possible. Im not sure if you need to remove them though.
Old Jan 21, 2009 | 02:03 PM
xBROKEx's Avatar
i didnt even take the pulley off, just use a short wrench
Old Jan 21, 2009 | 03:01 PM
nrs2420's Avatar
I hope that works because it's looking like I'm going to have to do this.
Old Jan 21, 2009 | 03:06 PM
FL-LS1's Avatar
Got a gm puller, worked great did in the car with the fans. Everything is replaced, now the rack is leaking If you need anything when you do it feel free to ask.
Old Jan 21, 2009 | 03:08 PM
nemss1's Avatar
y would u want to remove the fans???
