Sponsored by: CARiD
Some problems with my TA
Old Oct 7, 2003 | 05:02 PM
1RawTA's Avatar
Default Some problems with my TA
Hey guys, so im getting my car ready for Etown this weeknd, i check the oil im a qt low. the oil was only changed like 1800 miles ago. maybe 2000 at the most. so i pulled 2 of the plugs to see waht was going on. both plugs had a black ring around the base but the coil was pretty much whiteish, suppposly running lean i guess. What should i do now? why is it burning oil with only 28,000 miles on the car. i heard that running sytnthetic in the ls1 it will burn a little oil, and i heard changing the fuel filter will help the problem of the car running lean. waht are your thoughts? any tips of waht i should do?
Old Oct 7, 2003 | 07:57 PM
mike00ws6's Avatar
Default Re: Some problems with my TA
Hey I have a 2000 WS6 and I change my oil every 3 to 3500 miles and it's usually a quart low. I asked one of my friends about it and he said don't worry about it. It's good thing that uses a little oil. I have 45K miles on my car and she's running stronger than ever
Old Oct 7, 2003 | 08:06 PM
1RawTA's Avatar
okay i have acutally talked to a few of my freinds and i have heard the same thing from everyone, everoyne of them has said that when they change the oil every 3,000 they are a quart low, so nothing to worry about, im just gunna keep an eye on it and makes sure the engine dosnt run a qt low for prolonged periods of time . thanks for the info
Old Oct 7, 2003 | 08:43 PM
wrencher's Avatar
wrencher
Check the oil periodically & it'll be fine.
Old Oct 7, 2003 | 08:46 PM
onebadz's Avatar
Hey man i think if you do the pcv mod that will stop your oil consumption. I think that there is a write up on www.installuniversity.com.
Old Oct 7, 2003 | 09:48 PM
1RawTA's Avatar
thanks alot, so i guess i ahve come to conclusion that this is normal in ls1 fbodies? i gues ill do the pcv mod and hope it corrects the problem. any other thoughts?
p.s. after how many miles should i change my spark plugs, and what plugs should i use?
Old Oct 7, 2003 | 09:49 PM
1RawTA's Avatar
And about me running lean, should i change the fuel filter because someone said that may solve the problem
Old Oct 7, 2003 | 09:55 PM
onebadz's Avatar
Couldnt hurt, id also buy either a predator or a ls1 edit to see if your runnin lean or what.
Old Oct 7, 2003 | 09:59 PM
wrencher's Avatar
wrencher
^^ agreed^^ w/onebadz, you cant "read" the plugs for a rich/lean determination on a F/I street motor.
