A lot of moisture in tailpipes
Have any of you experienced this and know if this is normal? It was about 45 degrees last night here in S. Florida.
the temperature difference and condensation increases the affect so you are seeing water.
watch other cars on the road, you can see quite a bit of water come out of tailpipes under certain conditions, it'll drip drip drip quite a bit, more noticeable on imports where there's only 1 tailpipe with small diameter.
Or if you wash the car and hose water into the muffler that can do it as well.
but i did more research and it's normal...now with all the extra pipeing i have with my turbo set up, this is the 1st winter i've had it in....noticed a lot more condensation coming from her is all. thanks for the info.
