Sponsored by: CARiD
low oil light
Old Feb 2, 2009 | 11:48 AM
z28_YOU_HO's Avatar
Default low oil light
This has been on through about 3 oil changes now and it wont come off. I heard it may have something to do with the oil pressure sending unit?? The car is full on oil..
any ideas???
Old Feb 2, 2009 | 12:05 PM
2001NBMZ28's Avatar
The low oil light is supposed to come on when you're about 2 quarts low. In your case it's probably the sensor or wiring. It screws into the side of the oil pan.
Old Feb 2, 2009 | 12:54 PM
z28_YOU_HO's Avatar
could i simply just disconnect this?
Old Feb 2, 2009 | 01:45 PM
2001NBMZ28's Avatar
Good question, don't know if it's configured to work like the low coolent sensors were. I'd replace it if it's bad, used to be about $50 at the dealership, but should be cheaper from a local parts store. Take a look at the connector and wiring harness.
Old Feb 2, 2009 | 07:56 PM
camarolover209's Avatar
yea i recently broke my oil pressure sending unit since its right above the oil filter got one from autozone for like 30 bux if u disconnect it ur check gauges light will show and u will not know if ur gas light is on since ur check gauges is ur gas light
Old Feb 2, 2009 | 08:01 PM
TRANSAM/FORMULA's Avatar
my low oil light has been on for a while and i have tried to unplug connectors to make it go away but nothing...comes on goes. i did however unplug my low coolant plug and that light went away. bottom line----my cheap *** needs to buy some sensors.
Old Feb 2, 2009 | 08:17 PM
z28_YOU_HO's Avatar
^^ amen brother
Old Feb 2, 2009 | 10:03 PM
01ssreda4's Avatar
one of my wires was damaged i noticed while doing a stall install and i forgot to fix it and the next day the light came on. the wire looked kinda chewed up. i fixed it and havent had a problem since. its on the pass side btw.
