Sponsored by: CARiD
Rattle in the exhaust
Old Feb 19, 2009 | 01:49 AM
camarolover209's Avatar
Default Rattle in the exhaust
I have a 2000 camaro V6 3.8 Liter sometimes when i drive off or if im idling my exhaust tends to rattle and if i rev my motor it stops rattling and its been driving me INSANE and i have tried to deal with it for over a year wat should i do?
Old Feb 19, 2009 | 07:34 AM
slvr98camaro's Avatar
where is the rattling coming from?
my exhaust used to rattle against the driveshaft tunnel brace before i took it off and smashed it with a hammer a few times
Old Feb 19, 2009 | 10:01 AM
angel71rs's Avatar
Catalytic converter can also rattle if the ceramic inside breaks. Smack with a rubber hammer and see if the insides sound loose.
Old Feb 19, 2009 | 10:52 PM
ghardester's Avatar
I agree. I've had 2 3800 V-6's. My opinion is that your CAT is going out. Sounds like some gravel rattling around under the car somewhere. Well the stuff in the CAT is clumping up and you are probably a month or so away from getting a SES light and code.
Old Feb 20, 2009 | 01:20 AM
the rattle comes from the front and how do i make sure that the SES light doesnt come on?
Old Feb 20, 2009 | 01:22 AM
not from the front wat i meant is the back bumper im car is only a single exhaust and its right by the pipe it rattles somewhere there.
Old Feb 20, 2009 | 10:49 AM
ghardester's Avatar
When my CAT went out the rattle sounded like it was coming from under the passenger side floor board. If your rattle is coming further back you''ll just need to narrow it down and try to identify it.
Old Feb 20, 2009 | 03:21 PM
7998's Avatar
Mine used to rattle also, get a big stick or pipe and prod around different areas until the rattle stops. It turned out the clamp where the Y-pipe met the I-pipe was the culpurt(sp) on mine. It was extremely annoying but it would only do it when I was in drive at stop, I used just put it in Neutral to make it go away. Then one day I stopped being lazy and found out what it was and fixed it.
Old Feb 20, 2009 | 09:58 PM
nemss1's Avatar
my heatshields rattled because they were touching the top of the muffler. bent them upwards and solved my problem. check heatshields
Old Feb 21, 2009 | 12:35 AM
TransAmFSAS's Avatar
A not so common problem I've seen before is the over-axle pipe rattling on the cross member. Give that a look too maybe, they should not be touching.
Old Feb 22, 2009 | 12:39 PM
01Farburd's Avatar
I feel your pain. Mine rattles too. My tailpipe was hitting a little bit but I used a long metal rod and bent it a little. Now it is rattling again!! The best thing to do is get under there while it's running and see where the noise is coming from.
