Sponsored by: CARiD
Crank No Start!!!!
Old Feb 19, 2009 | 05:08 AM
Justins00ss's Avatar
Default Crank No Start!!!!
Well I have been having a itermittent issue with my SS doing a crank no start. I have a fuel pressure gauge and it reads about 58psi while cranking and doesnt drop so fuel is outta the question. The car doesnt show a check engine light eaither. I was wondering if it could be the Crank position sensor. Also is it possibly a leaky injector?? Is there a way to test for it?? How tough is it to replace?? Where on the block is it located?? The car is a 2000 SS Camaro M6. Thanks...
Old Feb 19, 2009 | 07:32 AM
slvr98camaro's Avatar
you need to check for spark before you do anything
if you are getting no spark from the coils, it could be the CPS
Old Feb 19, 2009 | 09:26 AM
sroach20's Avatar
crank sensor is right above your starter.
Old Feb 19, 2009 | 02:06 PM
john563's Avatar
had that issues when I first bought the car..Well after many dealships and changing the lock cylinder/new keys that did not solve it, it ended up being a $8 ignition relay..Swapped it out and all was good...5 years later get no start nothing,no cranking at all..It ended up being a starter relay..So before you do anything drastic try putting in a new ignition relay and see what happens
Old Feb 19, 2009 | 02:16 PM
jfg455's Avatar
Diag your problem before you start throwing parts at it or it will end up being expensive. If you have a fuel pressure gauge on it already then you can check for a leaking injector by turning the key on then off. Wait about 2 min and see if the pressure drops right off. if it holds then no leaks. CKP sensor can cause a no start and you will have no spark or injector pulse. check spark first its easyest. cam sensor will give you a long crank and start after 15 sec of cranking but it will run. course it will set a light as well. check IGN fuses. If one is blown then no PCM communication. try easy stuff before tossing parts at it. JMHO
Old Feb 19, 2009 | 03:58 PM
cool. Thanks guys, I will try some of these things when I get the car back from the shop. There going to take a look at it for me and see if they can find anything.
Old Feb 19, 2009 | 04:11 PM
john563's Avatar
relay was just a suggestion as it worked for me and at $8 its not to bad of a price to gamble with..But yes I agree with you at not throwing parts as one shop did (lock cylinder/keys) which were costly I ended up chancing it was an ignition relay I bought for $8 which did the trick
Old Feb 22, 2009 | 10:14 PM
Snipezzz's Avatar
