Drivers Side TB Hose???
What is the hose that runs from the passenger side of the TB to the valvecover? I think its cracked because my engine is running horribly at idle.UPDATE: Found out the name. Its the CCV hose. explains the problems im experiencing
Theres also a crank case pressure vent line. If there's a build-up of pressure it'll vent back to the intake that way, also oil goes back into the intake that way too.
Take pics if you can.
Tale pics if you can.
http://shbox.com/1/tps.jpg
Maybe an "air pump", which is used only at start-up, if its like the 1998+ LSx's.
