Coil Packs
TTT :/ Please I need to replace them I think. Im getting multiple p0354 ,p0355 ,p0356 and p0357 trouble codes when I use autotap to look at the DTC's . The car was fine then out of no where i got in and started it up and the Service Engine Light came one and the car felt like it had a huge miss . Thats when I hooked up autotap and saw the codes above in the log . Ignition Circuit #5 , #6 , #7 and another code for missfire I think it was p0300.
GM# 12558948
check www.gmpartsdirect.com they should have them or if you have a friend at a dealer too.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Ecklers ( www.ecklers.com ) its a corvette accesory place. the have em for 39.99 each. P/N 37731
I recently had the same problem. Check your plug from the harness. Mine was not quite as tight as it should have been, and moisture got in the plug & fouled it out. I got the complete coil pack (wiring & all) from Valvegod, for I think $25 each.
