Sponsored by: CARiD
car wont start!
Old Feb 23, 2009 | 04:01 PM
FiFdYnUtz's Avatar
Default car wont start!
so i just finished my ls6 intake and pp tb install and i took my car for a 5min drive and i noticed my speedo/tach/and a couple other gauges werent working but oil press was so i took it home and parked it, left for a couple hours, then came home to put it away and it wont start.
The radio and everything powers up when i turn the ignition on, but when i go to start it i get nothing, not even a click...so i put the jumper pack on it and still the same thing...my security light isnt flashing or anything..
So do you guys have any idea of what this could be or what i should check for?
thanks!!
Old Feb 24, 2009 | 01:25 AM
ls1whip's Avatar
go over every thing....make sure you have all your plug-ins plugged in, if thats good run it for codes
Old Feb 24, 2009 | 09:19 PM
FiFdYnUtz's Avatar
yeah i will have to scan it...what grounds should i look for that i would have tampered with doing the intake install?
Old Feb 27, 2009 | 02:37 PM
FiFdYnUtz's Avatar
bump?
Old Feb 27, 2009 | 03:00 PM
ls1whip's Avatar
you running headers or manafolds? did you leave the little vacume tube off the emmissions stuff that comes off from the manafolds? its on the left rear above the intake...umm idk man sometimes i just cant remeber what i took off soo i just check everything over...seems like mabey you might just have a plug mabey not "clicked in" all the way or somthing i meen changing the intake is not gonna mess with the rig not starting if you did it right which it sounds like you did.. is your check engine light on?
Old Feb 27, 2009 | 03:09 PM
1sick'98WS6's Avatar
Check the Cam position sensor, that would also explain the gauges not working properly. Your Rpm is determined from the CPS
Here is a picture of the sensor
Old Feb 27, 2009 | 05:28 PM
nemss1's Avatar
speedo is controlled by the VSS sensor. check that and related wiring also
Old Mar 1, 2009 | 05:18 PM
FiFdYnUtz's Avatar
the sensor behind the intake manifold?
Old Mar 19, 2009 | 08:59 PM
5ohslayer's Avatar
Ummm yes...
Old Mar 20, 2009 | 04:53 PM
taram118's Avatar
check the fuse for your gauges. and when your at it check them all. true story though if your fuse for your gauages is out then your car wont start.
