Sponsored by: CARiD
Big electrical problem
Old Oct 14, 2003 | 06:26 PM
AshF's Avatar
Default Big electrical problem need help asap
Ok, right now my car is recieving little to no power from the battery. I mean NOTHING has power. I was in a carwash today, and as always I turned off the engine, and just turned on accessory power so I could listen to the radio. Carwash ended, and I attempted to start the car. As soon as I turned the ignition, all power died, and that was that. The battery is fine, I've checked it for a charge. I have no idea what is wrong or how to fix it.
Old Oct 14, 2003 | 06:42 PM
Danny2tek's Avatar
Default Re: Big electrical problem need help asap
make sure the terminals aren't corroded (been there)
Old Oct 14, 2003 | 07:17 PM
ta12sec's Avatar
Check your ground also. been there
Old Oct 14, 2003 | 08:05 PM
wrencher's Avatar
wrencher
How old is the battery? Does the volt meter in dash work ? What does it show?
Do you have a volt meter?
Check voltage at battery direct & see what ya got.
