Ls1 no compression misfire**
could it be just a headgasket to fix the problem??? or valve issues..
how much is the cost to rebuild heads??...just trying to be able to drive it again and find the cheapest solution
any help would be appreciated thanks!
1. Blown head gasket
2. Cracked head
3. Hole in piston or broken rings
3. Cracked block
You will not know for sure until you tear it down and start looking.
How much do you consider "cheap", because none of those are going to be "cheap" to fix by most people's standards.
2. Cracked head
4. Cracked block
