Power Seat Motor
I'm having VERY similar issues with the TA seats I just installed in my Firebird.
As soon as I installed them, I tested the driver's side and it worked. Seat moved front back and lumbar support inflated/deflated. It did NOT move up or down though.
Got in car to move it, and seat still moved forward/backward, but no support, no up/down.
Passenger side inflates/deflates.
Clicking is heard whenever I push the driver's side buttons, but no movement.
How do I jump the 12v to the switch? I don't want to mess anything up.
Driver's side: Up/Down/Forward/Backward...no problems.
Lumbar/Bolster supports... not working. I hear what sounds like the motor trying to move on the passenger side.
Passenger's side: Bolster/Lumbar supports... work fine.
Any advice?
The air pump for both sides is under the passenger seat. If you hear the pump, obviously there is a pneumatic problem. My guess is the lines are detached or leaking. Other possibility is the bladders are damaged. If both the seat back and sides both don't inflate, it's likely just the lines.
When I had this problem, the driver side bolster/lumbar would actually make the passenger side bolster/lumbar inflate/deflate, as well as the passenger doing the same for the passenger.
I'm assuming since the tubing runs under the carpet and under the center console, and is whole (no connections in between) that those should be good. So that narrows it down the connectors from under carpet to seats (both sides) and then from those to the pumps themselves?
So 3-4 connection points?
Sounds simple enough.
