Power Steering leak?
If you can't see the leak and you don't have any puddles under the car - check your coolant. (Sometimes, the PS cooler will leak in to the cooling system.)If you have a PS Cooler leak, you'll probably notice alien-like slime on your coolant dipstick.
seems like 9 out of 10 times it comes from the pressure hose...
If having trouble locating the leak get some UV leak detector from autozone
get the free loaner cooling system pressure tester from autozone. pressurize your cooling system and look for bubbles in the PS resevoir to confirm PS cooler leak.
