Sponsored by: CARiD
Another car won't start thread.
Old Mar 12, 2009 | 06:18 PM
DrewSG's Avatar
Unhappy Another car won't start thread.
I woke up this morning to go to work and the car wouldn't start. When I would turn the key to start, all I would hear is clicking noise. After that, everything electrical in the car would shut off till I opened the car then everything would turn on again.
I tried jumping the car, the same thing happened. I pulled the battery out and took it Pep Boys and they said it was fine.
Is it the starter?
Old Mar 12, 2009 | 06:34 PM
LS6427's Avatar
Is it the starter?
If the battery is fully charged still, the alternator and the bettery should be fine. Did you check the fuses inder the hood, there's a starter one.
How did your overheating issue turn out?
Old Mar 12, 2009 | 07:18 PM
DrewSG's Avatar
You were right about the T-stat, I replaced it and the car has been keeping cool ever since.. I apologize for not returning my thanks
As for the current issue now, I haven't checked any of the fuses. I don't know which one to look at.
The weird thing is after I cranked it, and everything shut off dead, I popped the hood and everything turned back on.
Old Mar 12, 2009 | 07:22 PM
LS6427's Avatar
Sounds like some possible corrosion. It causes intermittent problems like that too. Are the wires all clean of corrosion? The ones attached to the starter too?
I found some corrosion a couple days ago on my damn stereo amplifier inside my car, that **** grows everywhere.
Check the starter fuse...its in one of those black boxes under the hood behind the drivers side headlight. They'll labeled.
Old Mar 13, 2009 | 08:38 AM
slvr98camaro's Avatar
i agree, i had a similar problem and it turned out my battery cable was loose
also, do you have an aftermarket alarm?
Old Mar 13, 2009 | 09:58 AM
DrewSG's Avatar
Thanks guys, I pulled and checked all the fuses and they were all good.
I also checked the wires for any possible corrosion and found none, I attached it back to the battery nice and tight and the car started.
I hope that was it, but the car was acting perfectly normal the night before it wouldn't start.
Old Mar 13, 2009 | 03:01 PM
LS6427's Avatar
If it happens again, look for corrosion on the wires that connect to the starter as well.
I've also had a battery a long time ago that had a terminal start to get loose in the battery. Where you attach it to the positive terminal, it started to spin inside there like it was stripped.
