Sponsored by: CARiD
TP angle 96%. How do i fix that?
Old Oct 18, 2003 | 11:22 PM
Kansas 99z28's Avatar
Default TP ANGLE 96%. How do i fix that?
I had the predator hooked up today and noticed that it said my tp angle was only 96% with it to the floor. What do I do to fix that. I did recently notice that my gas pedal had some slack in it as well.
Old Oct 18, 2003 | 11:23 PM
onebadz's Avatar
Default Re: TP ANGLE 96%. How do i fix that?
tb bump stop mod
Old Oct 18, 2003 | 11:38 PM
it doesnt go to the stopper. I had my friend sit in the car and floor and I grabbed it by hand and opened more.
Old Oct 18, 2003 | 11:39 PM
Its almost as if the cable was too long to not open it all the way. This is only recently it used to open 100% all the time.
Old Oct 18, 2003 | 11:49 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Do you have ASR? If so, you can easily adjust the throttle cable tension. There is a black coupler (looks like a big inline fuse) in the cable line between the ASR/TSC module and the TB. This is where you adjust the tension.
If you do not have traction control, there is no easy way to properly adjust the cable.
Old Oct 18, 2003 | 11:52 PM
I do have asr. I will go look at that right now and i'll tel you if it fixes it in a few min. thanks
Old Oct 19, 2003 | 12:09 AM
Smoke_Ford's Avatar
Ryan saves the day yet again...
Old Oct 19, 2003 | 12:21 AM
Ok, I went to take a look at it, but how do I make it tighter.
Old Oct 19, 2003 | 12:26 AM
RPM WS6's Avatar
I returned your PM.
Old Oct 19, 2003 | 07:19 PM
unit213's Avatar
Administrator
It's easy to remove the slack from the throttle cable when you have ASR. It's kind of difficult to explain though. Post up if you haven't got it yet and I'll explain how to do it.
Old Oct 19, 2003 | 08:10 PM
98pontam's Avatar
unit213, could you please post the directions.... i need to adjust mine also
Old Oct 22, 2003 | 01:20 AM
I fixed it in like 2 min. RPM WS6 gave me some good directions.
Old Oct 5, 2007 | 09:20 AM
Bad Blue WS6's Avatar
could someone share how this was done??
