Sponsored by: CARiD
Oil Change Light
Old Mar 14, 2009 | 10:52 AM
King Nothing's Avatar
Default Oil Change Light
ok this has has happened acouple times now, i changed my oil 2-3 weeks ago and reset the trip so the Oil Change Light wont come on till it needs to . . . well it came on and as soon as it came on my car started running rough when i was at an idle. i checked my air filter because when it's ran rough in the past it's usually some intake related and yeah my K&N was dirty as ****!!! so there's a new Fram in there and today i'm gonna pull the MAF off and clean that also just in case. plugs are tight on and i don't have any vacuum leaks i can see or hear but still what would cause that damn Oil Change Light to come on 2-3 weeks after an oil change??????
Old Mar 14, 2009 | 01:20 PM
DaddySS's Avatar
Reset it by doing the pedal method and see if it comes back.
Old Mar 15, 2009 | 02:43 AM
it does that i already know but my question is why does it come on after being reset?????? it doesn't do this everytime but it has done it quite a few times and eachtime my car will run like **** till i change my oil again
Old Mar 15, 2009 | 03:29 PM
W.hiteS.6's Avatar
same problem here..
Old Mar 15, 2009 | 08:19 PM
i'm glad i'm not the only one with this problem now let's find a solution!
Old Mar 18, 2009 | 06:17 AM
W.hiteS.6's Avatar
mine comes on ranging anywhere from 1 to 3 min just after start up (hot or cold no difference) then goes away. acts the same way with old oil, new oil, different oils etc.. i think it started acting up since i started pouring seafoam in there b4 every oil change but then agen i dont think that has nething to do with it. but i do kno the last time i changed my oil it smelt burnt and there was lotsa black "debree" i wiped off the magnet on the drain plug. i dont really notice any drivability problems or rough running but then agen this engine is so beasty i probably wouldnt even notice a misfire. only thing i can guess is my oil pump is on its way out but i guess ill just have to wait and find out.
..next oil change ima try that "Lucas" ill let u kno if it solves my problems
Old Mar 18, 2009 | 06:20 AM
yeah i'm at 145k and i'm wondering if mine is on it's way out also . . . i'm gonna put the new pump, timing chanin and 241 heads on end of the month and hopefully no more oil change light!
