Sponsored by: CARiD
Metal chunks stuck to oil plug!!!
Old Mar 16, 2009 | 04:40 PM
red98taws6's Avatar
Unhappy Metal chunks stuck to oil plug!!!
Hey guys,
I just changed my oil today for the second time since owning this car, and found these guys stuck to the oil plug...
Any ideas on what it could be? The car feels like it is running strong and I don't hear any knocks/other weird sounds.
Old Mar 16, 2009 | 05:28 PM
ROCNDAV's Avatar
could it be a side cap of one of your rockers? pull your valve covers and look at the sides of each of your rocker arms.
Old Mar 16, 2009 | 05:44 PM
LS6427's Avatar
Make sure to get a long, bendable magnetic stick and put it into the oil pan drain hole and sweep the entire bottom of the oil pan for more ****.
Old Mar 16, 2009 | 06:03 PM
TurdsOfMayhem's Avatar
That would scare the crap out of me. Hope you can find out what it was from.
Old Mar 16, 2009 | 07:38 PM
red98taws6's Avatar
Thanks everyone for your feedback so far
Any other ideas on what this metal might be?
Old Mar 16, 2009 | 07:51 PM
ddm3889's Avatar
Looks like the tops of push rods
Old Mar 16, 2009 | 09:19 PM
red98taws6's Avatar
If that were the case, wouldn't I be hearing/feeling it? The car seems pretty normal other than the chunks of metal
Old Mar 17, 2009 | 11:19 AM
ROCNDAV's Avatar
how thick are the pieces?
Old Mar 17, 2009 | 11:47 AM
bjamick's Avatar
Pull the valve covers and inspect your valvetrain. Its usually there.
Old Mar 17, 2009 | 11:49 AM
Nemo02Z's Avatar
I do not believe you do not feel that in the car. That looks like part of a piston skirt, looks like a cast part . were you running the dog **** of it prior to the discovery In any case i would drop the pan and pull the valve covers just for a piece of mind.
Old Mar 17, 2009 | 11:50 AM
Nemo02Z's Avatar
If it were part of the push rods or cam there would be a noticeable miss.
Old Mar 17, 2009 | 09:27 PM
red98taws6's Avatar
They are less than a millimeter thick. Probably about as thick as the average human fingernail...
Old Mar 17, 2009 | 09:31 PM
red98taws6's Avatar
Other than the occasional slippage from my worn clutch, it feels normal. I really don't beat on it too bad so I'm not sure what the deal is.
There was one case where I overevved a bit, I guess that may have done it.
Old Mar 17, 2009 | 10:01 PM
LS6427's Avatar
pushrod????
Old Mar 17, 2009 | 10:02 PM
LS6427's Avatar
I had pieces of spring seats break apart a long time ago, looks identical.
Or whatever the real name is for the round, washer looking things that sit under the springs on the heads in the round seats. They are about a millimeter thick, maybe less.
Old Mar 17, 2009 | 10:33 PM
samson_420's Avatar
Do a compression check, pull the valve covers and maybe the oil pan. Are the pieces magnetic?
Old Mar 17, 2009 | 11:16 PM
red98taws6's Avatar
Interesting...thanks for the insight!
Yes, they were stuck to the little magnet on the oil plug.
Old Mar 18, 2009 | 08:31 AM
samson_420's Avatar
Since they are magnetic, they are not pieces of the piston. . . . .
I really don't know. . . But, looks to me more valve train related.
