Sponsored by: CARiD
Help please!!!! Detonation
Old Mar 15, 2009 | 10:50 PM
ZERO_POLLO's Avatar
Default Help please!!!! Detonation
This morning I start the car and felt a little detonation at idle, I took her out for a ride and I can feel a small detonation at low rpm's then it dissapear at 2500 rpm, what can it be. I'm worried and lost.
Please help me out.
Old Mar 15, 2009 | 10:55 PM
ItsNotStock's Avatar
Is the ses light blinking?
OUTLAWZ RACING's Avatar
Change the gas or add a octane booster. Also check your fuel filter.
Old Mar 15, 2009 | 10:56 PM
Dmoney's Avatar
Angel, give me a call tomorrow and I can scan your car to see what's wrong. I'll PM you my number....................
Old Mar 15, 2009 | 11:01 PM
LS6427's Avatar
detonation at idle???????????
Its more likely a miss.
bad gas.
dirty injectors.
dirty fuel filter.
dirty maf.
wires touching a header.
bad wire arcing.
Old Mar 16, 2009 | 07:32 AM
ZERO_POLLO's Avatar
thanks guys, Im gonna check today.
Dan I give a call later on today.
Old Mar 17, 2009 | 09:43 AM
colby72olds's Avatar
Did you get it fixed? I think mine is doing the same thing. I've changed the fuel filter, put in some injector cleaner, made sure all my wires are connected, and my plugs are about one month old. I just got a tune about 3 weeks ago and it's been running great, up until Saturday.
Old Mar 17, 2009 | 02:05 PM
ZERO_POLLO's Avatar
I triple check the spark plug wires, and took it with a friend and he check the same plug wire and discover that one of them had a crack and the spark was hitting the header, I replace the wires and LIFE is good again.
Old Mar 17, 2009 | 02:10 PM
Did it run rough the whole time or would the problem come and go?
Old Mar 17, 2009 | 02:14 PM
ZERO_POLLO's Avatar
First was between 1500 and 2000 RPM then it became worst the whole RPM kind it like it was missing fuel. I would change each cable for any cracks on them before you move to something bigger. I also clean the MAF sensor.
Old Mar 17, 2009 | 02:30 PM
ok cool, I'll recheck my wires when I get home. Hopefully that's all it is...I'm crossing my fingers.
Old Mar 17, 2009 | 03:39 PM
LS6427's Avatar
BINGO............a miss.
Old Mar 17, 2009 | 03:42 PM
LS6427's Avatar
If one is, best way to get it off the header is to spin the boot that is attqached to the coil until it comes off the header.
