Sponsored by: CARiD
Whats the catch
Old Mar 17, 2009 | 04:33 PM
Formulals187's Avatar
Default Whats the catch
I was changing my spark plugs today when i got to the passenger side bank i noticed i couldn't get my hand down there. Is there a secret to changing the passenger side bank spark plugs.
Old Mar 17, 2009 | 04:52 PM
LS6427's Avatar
small hands, small tools. some people go at the #8 plug from the bottom too. First time I did it I literally said to myself, "this is NOT going to happen." Now I do that whole side in 20 minutes flat from start to finish, pretty much effortlessly.
Old Mar 17, 2009 | 04:56 PM
waldershrek's Avatar
Do it from the bottom
Old Mar 17, 2009 | 04:58 PM
1987firechicken's Avatar
You have headers yet, and the AIR still installed? I fished my hand along the top of the header just fine.
Old Mar 17, 2009 | 06:55 PM
FiredUpZ28's Avatar
No A/C makes it easier
Old Mar 18, 2009 | 06:49 AM
wssix99's Avatar
Save the manuals!
http://www.slponline.com/view_product.asp?P=30102
Old Mar 18, 2009 | 09:57 AM
AR15 guy's Avatar
I just use a 3/4'' wrench and a spark plug socket. It can be done, just not easily.
Old Mar 18, 2009 | 03:20 PM
MTN_Z's Avatar
Remove the coil packs and leave the back bolt out of the bracket when you are done so you don't have to worry about it the next time. It's pretty easy this way because it opens up enough room to get a ratchet with a swivel down there.
Old Mar 18, 2009 | 03:22 PM
Super Speed's Avatar
x2 use a small ratchet and swivel and remove the coil packs!
Old Mar 18, 2009 | 05:32 PM
wht01ws6ta's Avatar
Removing the AIR helps a ton, unbolting pass side coil pack helps a little, I go up from the bottom for #8. And I ground down all of the sadistic spikes on the coil packs because those things can be brutal anytime you are working in there.
Old Mar 18, 2009 | 08:56 PM
98TAjwh's Avatar
time+patience
