Sponsored by: CARiD
knock sensor
Old Mar 29, 2009 | 06:55 AM
98z8uup's Avatar
Default knock sensor
I am having a hard time uderstading what really make the knock sensor code come on.someone help.
Thanks
Old Mar 29, 2009 | 09:53 AM
peterock98's Avatar
Harness corrosion can cause it ,this will give you a faulty connection or the connection is loose make sure it's plugged all the way in last the knock sensor is bad .
Old Mar 29, 2009 | 07:01 PM
question's Avatar
How many knock sensors do we have, and where is it located it?
Old Mar 30, 2009 | 08:20 PM
peterock98's Avatar
2 under the intake manifold
Old Mar 30, 2009 | 08:44 PM
NonGoggleGuy's Avatar
The knock sensor is a piezoelectric switch that basically operates on sound. It senses a "knock" sound coming from the block and sets a DTC.
The KS senses an over-advanced timing characteristic (a ping in the engine) and sends it to the PCM. The PCM then retards the timing. It could actually be a bad sensor, or it could be a bad signal to the PCM, due to noise or a bad connection.
Old Mar 31, 2009 | 01:13 AM
98z8uup's Avatar
Thanks, now I have a better understanding of it.
