Sponsored by: CARiD
Help with rubbing noise when turning.
Old Apr 5, 2009 | 09:05 PM
05GTOtennessee's Avatar
Default Help with rubbing noise when turning.
I recently bought a 2002 Z28. When I bought the car it was already lowered. I didn't notice it at the time but there is a rubbing type noise from the rear when turning especially to the right. It sounds like a tire rub. It has ZR1 17's out rear with 275 40's. It also feels wierd if you turn the steering wheel quickly right and left, real floaty feeling. I know this description is not really good but any ideas will be appreciated. Lee
Old Apr 5, 2009 | 11:26 PM
motoo344's Avatar
I have the same thing going on right now. Could it be a tire rod or something? I honestly have no idea, but I would like to know also.
Old Apr 6, 2009 | 07:04 AM
Mine is in the rear. I don't know much about lowered cars but maybe something is off alignment wise since someone lowered the car. Not sure what it could be or how to fix it though.
Old Apr 7, 2009 | 07:13 AM
Anyone.....
Old Apr 7, 2009 | 07:24 AM
RsSean's Avatar
If it is in the rear see if the tire are rubbing the inner fenders. OIr the bump stops.
Old Apr 7, 2009 | 07:33 AM
z28voodoo's Avatar
since it is lowered it may not be aligned, you may want to measure and see. It probably needs a panhard bar to align it.
Old Apr 7, 2009 | 05:33 PM
What would the bump stops be rubbing. I checked the inner fender clearance and am thinking that it isnt rubbing there.
Old Apr 7, 2009 | 05:34 PM
If I had an adjustable panhard rod would an alignment shop be able to line up the rear then?
Old Apr 7, 2009 | 05:37 PM
sic2001's Avatar
I had the same problem. I put a spacer on the hub and it was fine. Mine was rubbung on the inner lip, if you take the wheel off there was a scuff mark on the paint on the inner wheel well.
Old Apr 7, 2009 | 08:12 PM
I guess I need to pull the wheel off and see if I can find a rub point on the inner fender.
