Sponsored by: CARiD
weird "RATTLE" in back of car
Old Apr 7, 2009 | 09:48 AM
Circa307's Avatar
Angry weird "RATTLE" in back of car
ever since i have had my TA it was had a BAD rattle at the idle RPM range. when im stopped at a red light or something like, the back passenger quater panel or B pillar will rattle loud. i let my gf drive it down the road and i could even hear it from outside the car. Its not my tag or my anntena bc i have taken both of them off and it still does the same thing. thank you ahead...
Old Apr 7, 2009 | 09:59 AM
Zerokube's Avatar
Check your exhaust. sometimes mine does that and i know its something that's hanging up my exhaust. ill take a picture of where its at and try to post it to show you.
eseibel67's Avatar
Your fingers will find the problem.
While it's idling, just keep on touching everything in the area until the noise stops or changes pitch.
First I would check the spare tire or jack.
Good luck. Buzzing/rattling noises make me nuts.
Old Apr 7, 2009 | 10:08 AM
Circa307's Avatar
never thought about the exhaust. ill check it out. I have already taken my spare tire out and even unbolted all my alarm crap back there and still it rattles. p.s. you guys must be bored at work like i am bc yall responded fast.
Old Apr 7, 2009 | 02:20 PM
Zerokube's Avatar
iPhones for the win
Old Apr 7, 2009 | 09:22 PM
blkOWT's Avatar
my lt1 has the exact same problem...
tomorrow...im gonna turn it one and put my hand on the exhaust and feel around like eseilbel67 said...hopefully i find the problem.
cause it sounds like my exhaust...
Old Apr 8, 2009 | 06:01 AM
eseibel67's Avatar
Exhaust gets hot fast. Use a rubber hammer immediately after startup, or use a wooden 2" X 2" so you don't get branded.
Check muffler heat shield as well.
Old Apr 8, 2009 | 08:16 AM
NonGoggleGuy's Avatar
Yeah, I agree. It's most likely a loose or broken exhaust mount.
Old Apr 8, 2009 | 08:27 AM
m6speed's Avatar
mine was doing something really bad like this at certain rpm ranges and my buddy started feeling around the back passenger area and finally found the problem, turns out there was about 5 dollars worth of change under the carpet LOL
Old Apr 8, 2009 | 11:32 AM
_JB_'s Avatar
X2
My heat shield ratted all the time, so check that.
Old Apr 9, 2009 | 12:40 AM
Circa307's Avatar
Talking
thanks guy. im going to check all that stuff tomarrow( off work ) and ill let yall know how it turns out. never even thought about the exhaust but it makes sence.
Old Apr 9, 2009 | 11:56 AM
Trojan35's Avatar
exhaust hangars. first time one of mine broke and had a local shop fix it for $20 because I was lazy.
Then it started rattling again, so I jacked up my car and realized the idiot put the brand new hangar on backwards so it broke again.
Fixed it and haven't had that god-awful loud rattle since. Now I just need to fix the passenger seat rattle (which appears to be in the adjustment gears somewhere. maybe it's time for aftermarket seats).
Old Apr 9, 2009 | 01:22 PM
z28voodoo's Avatar
If it sounds like its coming from inside the car rather than the outside, check your rear seat seatbelts and the latch that lets the rear seat down. Mine rattles there if the seat belts are turned wrong.
Old Apr 9, 2009 | 02:39 PM
TRANSAM/FORMULA's Avatar
I had a horrible squeak in my car and i found out that my hatch prop rod was broken on the mount on my hatch. Not sure yet how i am going to fix it yet so i just took it off to stop the squeak. btw man that hatch is heavy now lol. to top it all off i just aquired a new squeak and i'm not sure where this one is. i have a borla exhaust and check it and it was fine.....damn this ***** annoying. i will let you know what i find out.
Old Apr 10, 2009 | 05:17 PM
camarolover209's Avatar
Check your cat converter my rattle is all from my cat got a new cat and no rattle
Old Apr 10, 2009 | 07:08 PM
Ryanmgaspard's Avatar
Kind of weird but I thought I had rattles which turned out to be a low rpm pinging. A tune did the trick. I swore it was my exhaust though but nothing was touching and it sounded like a loose washer hitting a bolt.
Old Apr 11, 2009 | 02:01 PM
Circa307's Avatar
Talking
aww.....the joys of owning a 10 year old f-body. but a C4 vette is way worse. i even had a late model c4
Old Apr 11, 2009 | 02:13 PM
jsteele90's Avatar
my forward lca bolts were loose on both sides check them. mine rattled horribly
