Sponsored by: CARiD
reverse lights not working
Old Apr 20, 2009 | 03:49 PM
Taken4granted's Avatar
Default reverse lights not working
I notice last night when I put the car in reverse that the lights did not go on, all other lights work...brake, signal but no back up. I popped out one of the lens and check the bulb and it wasn't burnt out I haven been able to check the other due to it raining does anyone know what might have cause this?
Old Apr 20, 2009 | 03:55 PM
NonGoggleGuy's Avatar
The bulb may look good, but could still be bad. Also check the fuse for the backup lights.
If a bulb fails shorted (very rare), you will blow a fuse.
Old Apr 20, 2009 | 04:00 PM
the fuses located near the driver door correct??
Old Apr 20, 2009 | 05:29 PM
Yeah, it should be there.
Old Apr 20, 2009 | 08:38 PM
wssix99's Avatar
Save the manuals!
What kind of trans?
Old Apr 20, 2009 | 10:01 PM
WnaSty6's Avatar
there is a reverse light switch on the tranny, if you have a manual, right side of tranny housing for V8's and left for V6's. If you have a auto it will be located inside the console and it is probably out of adjustment. If you have a haynes manual look in chapter 7.
Old Apr 21, 2009 | 01:54 PM
well the rain let off finally and I check the fuses and they all look fine, all my bulbs are fine too so what gives
M6 of course
Old Apr 21, 2009 | 02:38 PM
well I jack'ed up the car a located the reverse light switch on the tranny Ill have it checked out tomorrow
Old Apr 21, 2009 | 02:50 PM
bad_408_vert's Avatar
I had same on my a4. The bulbs looked good but both were out.
I doubt its reverse light switch, start with easy things first.
Stop by autozone n pick up the bulbs before you do anything else.
Its $5 a pair.
Old Apr 22, 2009 | 08:32 AM
PAGregSS's Avatar
I had the same issue. It was the reverse switch on the tranny. Easy to replace.
Old Apr 24, 2009 | 12:41 PM
how much would that switch cost...ballpark figure
Old Apr 24, 2009 | 12:46 PM
tavi_ws6's Avatar
it was around 10$ when i replaced mine
