Sponsored by: CARiD
low oil pressure, replace shortblock?
Old Apr 21, 2009 | 11:23 AM
lt1noob's Avatar
Default low oil pressure, replace shortblock?
a guy i know has been having low oil pressure in his lt1, ive thought about it and its probably either main bearings or oil pump failing. now either way the engine needs to be pulled and i kind of wondered, would he just be able to find a used bottom end/shortblock and just swap that in? as long as everythings in good condition and working order would that be fine? any other suggestions are welcome.
Old Apr 21, 2009 | 11:51 AM
SparkyJJO's Avatar
If you're going to go through all that why not just rebuild your own?
Old Apr 21, 2009 | 12:00 PM
lt1noob's Avatar
im thinking itd be cheaper and a little tiny bit less of a hassle. but i suppose if we completely tore heads/intake everything off it wouldnt take much to change the bearings at that point anyway. so would we just need to change what, main bearings and maybe oil pump?
Old Apr 22, 2009 | 11:19 AM
lt1noob's Avatar
so itd be better if he just got a rebuild? how much would that run $$$ wise if we payed a shop to do it?
