Turn Signal Problems
Problem:
turn signals dont work
wont light up on dash
will click when move up and down
hazards work perfectly
What i have done:
changed the silver (flasher) thing
replaced all bulbs
checked ground in rear hatch area.
now what i have done also recently is replace the ignition switch...so idk if it indirectly relates to it or not....but any advice would be appreciated.
Also at the flasher there should be a brown and a purple wire. There should be power at the brown wire and the purple wire should flash with the t/s on.
i was finally able to get some time off work....
i know i replaced the t/s blinker unit because it is the one that is closest to the center console....
i checked and i have no power going to either the purple or the brown cord....
now i dont know where to go from there..
**and just clarifying...i know that the turn signal wont work while the hazards are on...so its not me trying to do both at once...**
kinda at a loss for words as to how a simple blinker can take a car off the road
the fuse is perfect....but i bought a new one anyway and installed it...still nothing...
i checked the turn signal and nothing. so just to make sure i checked the hazard and there is power.
so i am NOT getting power to the turn signal fuse!
and the reverse lights do NOT work!
i hope you have an answer to that one! seems like you do!
does this mean i need to drop the steering column? what do i need to do next?
and thanks for your help!!!!
so i re-dropped the steering column, took out the ignition switch i had just replaced... took it back to advance auto parts...bought one from orielies, installed it, and bam! the sucker has turn signals reverse lights, and every single power option working!
Thank you soooo much 02 35th LE!!!
you were such a big help!
