Sponsored by: CARiD
tachometer problem!
Old May 17, 2009 | 12:12 PM
redbadss's Avatar
Question tachometer problem!
when i start my car up cold everything is working fine, but the last 2 days when i start the car up for the second time (like say when i was at wal mart coming home) the tachometer just sat at 0 for the whole drive home?never moved.. i haven't touched anything that would have to do with the tachometer. any suggestions what it might be?
Old May 18, 2009 | 03:30 PM
redbadss's Avatar
anybody ever have this problem before? when i started the car up today after school the tach didn't move at all all the way home. it just stayed at 0.
Old May 19, 2009 | 01:39 AM
The Crazy Sweed's Avatar
I have this problem as well on my '98. I went in with a obdII reader and found an trouble code, i just deleted the code and the gauge started to work again.. for 1-2 ohurs and then it went totaly dead.. I dont know the actual problem, but certifyed gues is that some recistor or the coil for the tach has ben worn out.. witch realy sucks.
Old May 19, 2009 | 09:25 AM
redbadss's Avatar
would a diablosport predator programmer be able to delete the codes? thanks for the help man.
Old May 19, 2009 | 01:35 PM
MY99TAWS6's Avatar
My tach went intermittent and now is generally dead. I have codes for cam sensors. The cam sensor can make the tach go intermittent or dead. If it does this you will have some other symptoms..harder to start and rough idle worse mileage. The car reverts to batch fire from sequential.
The cam sensor would set codes like 341, 342..Wierd how the tach is driven off it and wierder is my rpm still shows right on the scanner.
Old May 19, 2009 | 03:37 PM
redbadss's Avatar
everything is running perfect, just the tachometer stopped working. no rough idle or worse gas mileage. my car is relatively stock
Old May 19, 2009 | 04:50 PM
MY99TAWS6's Avatar
So it doesn't start harder or throw any cam sensor codes? then maybe just a broken tach? or is there fuse for it
Old May 19, 2009 | 07:42 PM
redbadss's Avatar
no it starts the same, im thinkin it could be a bad fuse, cause it works for a while then goes out, i think if it was broken it wouldn't work at all.
Old May 20, 2009 | 02:40 AM
Same with mine.. starts great and runs great. havent found any codes for the sensor. bad fuse in the cluster then because there is none for just the tach otherwise.. I think a condenser or a diod has gone bad..
Old May 20, 2009 | 10:54 AM
redbadss's Avatar
do you know where the condenser or diods are located? i was looking at the fuses yesterday and all are good as far as i can tell.
