Sponsored by: CARiD
Ignition Fuse
Old Nov 4, 2003 | 12:38 AM
Flamed350's Avatar
Default Ignition Fuse
I blew two of these fuses saturday back to back and by looking at the fuse that's in there now it doesn't have much time left on it either...just wondering what could be causing this to happen...also the car does have a miss...all plug wires are ok...just changed the plugs..maf is ok...opti seems to be ok..or at least it does feel like the opti...i've went through 3 of those...just driving around it will all of a sudden bogg down, i can let off the gas or give it a little more then it will quit. also...it's made my car way off at the track...last time out i ran a 12.7 with a 1.91....saturday i ran a 13.16 with a 1.85...my 1/8 mile was off from my last run by .3 and my mph was down 5 from the last run..just wondering if you guys would have any suggestions. i do have autotap but im throwing a cranksensor code right now and it won't show any misfires. Any help would be appreciated..thanks
Chad
Old Nov 4, 2003 | 09:28 PM
Gangly's Avatar
a buddy had the same problem and it was his crankshaft position sensor.
