a/c blew up
Or, I've never heard of it tried but I don't see why it wouldn't work perfectly. Get a two ended brass fitting that fits into that size hose. Cut the rip out of the hose about 1 inch in both direction. So a 2 inch piece. Then slide each hose end over the brass fitting with clamps o neach end of the brass fitting. There's no way I can see it leaking from the pressure thats in the system. I would damn sure try this simple, possible fix, before I changed that headache of a line.
If not, buy the #10 hose from ebay.
http://www.lowes.com/lowes/lkn?actio...il=&lpage=none
But who's to say it just won't blow another hole somewhere else in the line.
Thats friggin exactly the brass fitting I mean. Don't go ****** nuts tightening it down, you don't want to rip into the rubber by squeezing the **** out of it. Maybe find a type of clamp that is completely flat on the side that touches the rubber, then you can tighten the **** out of it.
I think its gonna work perfectly. I see no reason it won't.
I couldn't do this with mine, my leak was right at the metal coupler. I'd have to cut that metal couple off and slide the rubber hose over the metal line, then clamp it down. ****, that would work too.
2 cans should do it. Don't put 3 total cans in though. Maybe a little bit from a 3rd can.
Damn man, it'll be very cool if that holds up. That would be a great write-up fix for people. Changing those lines suck ***.
BTW....I was a North Ft. Myers "Red Knight" back in the day. Lived in WaterWay Estates off Orange Grove Blvd.
The best way to do it is with a machine that will pull a vacuum and refill the system to the right amount.
How did you recharge it? If you used one of those can things with the gauge on it they aren't that accurate. The ones that come with PAG oil in them too can overfill the compressor causing the seals to become damaged and leak.
